Can someone explain this
SLM89
The Infinity 310A is a 1 channel amp that says
2 ohm output power - full range is 312 Watts
and
briged power @ 2 ohms - full range is 294 Watts
My two Infinity 1230's are 4 ohms and in parallel together they are 2 ohms. How much power will my subs be getting?
according to your stats your subs will get 294 watts but that sounds like its the max not rms
SLM89
thats the only numbers i see, i dont know if its rms or not.
SLM
wait... RMS Power at 2 Ohms 312 W x 1
will my subs get all the power wired in parallel or will it be half?
yeah you will 312 W x1 bridged when your subs are wired in parallel if you wired them in series it cuts in half so wire them in like you said in parallel
that amp is rated at 116w x 1@4ohms and 312w x 1@2ohm but what is the rms for each of those 1230 subs cuz it sounds like you are underpowering 2 subs unless you mean you had just 1 sub although the rms on those is 300 so you will need to set your gain according to what the voltage is out of your HU to your amplifier
Username: Rds11
Louisville, Kentucky
Post Number: 214
look it puts out 312 at 2 ohms then that 312 is split between the two subs. giving 156 watts to each sub, you are underpowering them
SLM89
even if i wire them in parallel? Wiring them in parallel gives each sub the max power, am i wrong about this? it shouldn't cut it in half
SLM89
SLM89
no? yes? in science a few years back, i remember my hairy science teacher Mr. Gorkoff tell us parallel is way better because both things get all the power instead of half.
SLM89
bump
SLM89
bump
LOOSEWHEEL
What RDS said. Max O/P is 312W into 2 ohms. The amp will see 2ohms when they are paralleled, therefore each speaker gets 1/2 or 156W. 156w + 156W =312W.
