Comps for a ford ranger
Username: Algirard1
OH United States
Post Number: 84
Right now I have 4 6x9's in my ford ranger extended cab. I will be getting a 15" Avalanche and I need some good components to match. I will be getting rid of the rear speakers so I only need components for the front. I know that I would be better of getting round components not oval. What size of component will fit in the 6x9 hole. I am looking for components that are around 100 watts rms. Could you please suggest components. Please keep the price sort of low but give me a good set. Thanks
Username: Jonathan_f
GA USA
Post Number: 3805
How low do you want the price to be? They're really 6x8s, but a 6.5" will fit in there IF you make a custom mount for it. I recommend wood, preferably marine grade plywood or you could treat MDF such as by painting it or sealing it.
Username: Algirard1
OH United States
Post Number: 87
I don't want to spend more than 200 on components. Any suggestions wouold be helpful.
GA USA
Post Number: 3814
Look into CDT and Infinity, both offer great components for the price online. With Infinity, you can look into the Kappa components, CDT you can look into the Classics.
