Dimensions for Atlas 15 sealed?
Username: Pharoh
Bradford, Ontario Canada
Post Number: 198
I am either doing my 2 atlas 15's in a sealed ancloser to about 7.8 ft3, or an IB setup. Can someone post up some dimensions for sumthing near 7.8 ft3 sealed box?. Im going to see wht sounds decent and has hard bass.
Username: Insearchofbass
Post Number: 1642
32 x 15.5 x 27.25 internal is 7.82 cf.....so 33.5 x 17 x 28.75 external using .75 mdf
Post Number: 1643
add .75 to your width if you want to add a center divider for the subwoofers
Username: Pharoh
Post Number: 204
what about a single 15?. I should have said that first :P
Post Number: 1676
32 x 15.5 x 13.50 3.87 cf...these are internal measurements external would be 33.5 x 17 x 15 using .75 mdf
