Lounder BASS
Username: Vaio
Post Number: 54
I will like to get Harder hiting BASS out of my 4 12" (sound stream) XSTREAM Series. Ok not the best but i got 4 of them. how can get the bass hit harder. I have them in a 16"D X 49"W X 22"H Box i know its a big box it sound very good. But i will like To sound GREAT.
Username: Vaio
Post Number: 55
What can Put inside the box for the can hit harder?
Username: Vaio
Post Number: 56
any one
hey man, what you can do to get a different sounding bass if put like insolation or a pillow in your box, im a drummer and i put pillows and blankets in my bass drums...it will make your bass give a more definded kick that wont echo out so much. your other option it to us a sound reflective material on the inside of your box and inside of your trunk, u can get this at any car audio store but its going to cost you. oh yah if u want a longer deeper bass, port your box if it isnt already. u gotta be sure that the box is big enuff for it to be ported, but from the sounds of it, it is
hope this helps
richard
