30 or 15 band equalizer
Username: W00b
Post Number: 53
i need a good 30 or 15 band equalizer, can you list me some models so i can check them out? any comments on the models would be appreciated aswell.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7578
30 band would be 1/3 octave.
Audiocontrol EQT
Orion DEQ-30
Orion Concept 97.2
there are numerous others. the EQT are what I use in my car at present. you'll need an RTA to set them properly as with any 30 band EQ
Username: W00b
Post Number: 55
ok, can you maybe suggests some places to get these online? i live in a relatively small town and i really only have chain stores (best buy, circuit city) i have never seen equalizers there. thanks
Username: Carguy
Post Number: 2361
eBay is your best bet then. CrappyBuy and CC will not carry anything worth purchasing.
The RTA is a very cool item. I have one for my car. It looks very impressive at night.
Username: W00b
Post Number: 56
audiocontrol EQT is discontinued, i called them up and they suggested the DQT "digital" equalizer, how does that compare to the EQT?
Username: Glasswolf
Post Number: 7593
should be at least as good, probably a bit more money, and if it's digital you won't have any phase shift associated with the EQing which is good.
you can find pairs of EQTs all over ebay if ya want a cheaper option, too.
Username: W00b
Post Number: 63
http://www.alesis.com/products/deq230_230d/
how about this one? it looks pretty good.
Username: Glasswolf
Post Number: 7706
umm, that's for home audio.
ThatGuyYouKnow
Glass I rember in one of your install pics on your site, someone also has somthing close to that in their trunk.
Im just saying.
Username: Glasswolf
Post Number: 7775
yes those were USD noise gates.
they were to achieve a zero noise floor in the car with the 12VDC system.
also in order to use them the entire power supply setup for each one had to be custom reworked.
