Dimensions for a box
Username: Jthree
Bay area, Ca Usa
Post Number: 56
what would be some good dimensions for a box that will enclose 2 eclipse 12 inch ti's? and i want it to be sealed. any would eb helpful. and what amp do you think would power them well?
Username: Nnnnick_b
Nc Usa
Post Number: 325
2.5-3 cuft. i guess. Look for the manufacturers recomended enclosure size.
Username: Jthree
Bay area, Ca Usa
Post Number: 57
yea i know the recommended volume, but im asking for dimensions.
Username: Insearchofbass
Post Number: 1636
28.5 x 13.5 x 13.5 internal is 3.00 cf total for 1.50 cf a piece) both subs so 30 x 15 x 15 external measurements thats without displacements for the subs
Username: Jthree
Bay area, Ca Usa
Post Number: 58
i figure about 14 inches in height 11 inches in width and 32 inches in length, does that sound good? and what type of material should i use for the enclosure?
Post Number: 1637
thats with no divider if you want to add one add .75 on your width internal...all this is using .75 mdf board
Post Number: 1638
thats with no center divider seperating the subs....if you want that add .75 on your width internal ...this is using .75 mdf board
Post Number: 1639
if your measurements were internal which i assume they are your at 2.85 cf
Post Number: 1640
14.75 x 11 x 32 is 3 cf internal also
