What speaker should i get?
Username: Langner
Madison, South dakota US
Post Number: 99
I am probably going to replace my 5x7's in my car and possibly get an amp dont want to spend over 150 on the speakers what would be a good set of speakers and a good amp 2 power those speakers?
Username: Robste15
Post Number: 16
a set of infinity kappa 5x7/6x8's are really good that will handle 100watts rms, then get a good 2 ch. amp that is rated at around 90w x2 rms
Username: Robste15
Post Number: 17
you can buy the infinity kappa572.5cf's off of onlinecarstereo.com for $99 which i think are worth it because my friend has them in is vehicle running them with an amp and they sound really good
Username: Hooli
How do I match speakers to my head unit?
I own a Sony CDX R3350 head unit and want to beef up my car steroe sound (not enough bass in the factory speakers!).
I want to buy some 6x9 speakers that are a good match to that head unit, which says it produces 4x50W RMS (I found one technical spec that says the unit produces 4 x 23.2W...a little confused by this!).
I'm looking at some Alpine SPE6903 speakers which say they are 30W RMS. Good match?
If I leave the factory speakers in the front and wire the new 6x9s to the rear outputs will my head unit cope with the different output requirements for the speakers (factory fronts and 6x9 in the rear)?
Sorry the questions is so basic :-)
Username: Robste15
Post Number: 32
the alpines would be fine and sound good off that HU
Username: Robste15
Post Number: 33
50x4 is the peak and 23.2x4 is the HU's RMS which is what you look for in matching speakers
