I want to know if i will be satisfied with two l7 15"S
kiklir
IS a audiobahn 1200 watt amp enough to power them without an extra battery or special alternator
Username: Ridinlow987
what class of amp is the 1200? if it is an a,b,c then no but if it is a class d then yes it will push them both with no problem just be sure to wire the subs as 1 rather then individually
