Confused on installation
Username: Goon
Post Number: 144
i'm confused on how to hook up the crossover on my infinity refs. i want to put the tweeters in, something i have not done yet. can anyone shine some light on this for me? is the crossover a must? thanks,
goon
Username: Jwbulger79
Florida
Post Number: 507
yes. crossover is a must.
run the speaker wire from your amp to the two terminals on the left labeled "IN", then run wire from the next set of terminals labeled "WF" to the big speaker. next run wire from the set labeled "TW" to your tweeter. if the tweeter is too bright, you can lower its volume by swiching the wire on the crossover from the "TW +" terminal to the "-3db" terminal.
have you read the manual?
Username: Goon
Post Number: 149
www.infinitysystems.com didn't have a manual for the refs, so i read the kappas...ok it makes sense now. thank you very much.
goon
