Is it enough
Username: Cenus
Hicksville, Ohio Usa
Post Number: 58
http://www.woofersetc.com/product.asp?0=337&1=338&3=2481 is that amp enough to push 2 avalanchs its a kicker kx 800.2
Username: Subfanatic
Walton, Ky
Post Number: 2947
i doubt it
Username: Cenus
Post Number: 59
could i just mono the amp and run 1 18inch avalanch
Walton, Ky
Post Number: 2954
yea that would be nice, but i think the sub comes in svc 2 ohm so u would have to wire it at 2 ohms and that amp isnt stable lik eht, but hey im prolly wrong, maybe a difference voice coil configuration
Username: Cenus
Post Number: 60
ok ill check out their website to see the voice coil configeration
Username: Cenus
Post Number: 61
ya your right about the wiring. is there any other amp that would push 1 with no problem
Username: Cenus
Post Number: 66
would the mtx 6500d amp be enough to push 1 15inch avalanch its 500rms @2ohms @12.5 volts
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 273
im like 98 percent positive that the 18 avalanche is dual 2 ohm ... i just ordered a 15 avalanche and i KNOW its dual 2 oh,. i would think that the 18 would be the same. also at the bottom of the specs for the 18 avalanche on their site it says dual 2 ohm wired in series
Username: James1115
Wilton, Ct
Post Number: 2597
yes its dual 2ohm not single 2ohm. The amp to run it with would be Orion 250HCCA g4,JL 1000/1, and that kicker you posted the 800.2 will run it very well also.
