10w6-v2 and 12w6-v2
somethingrediclousihavetomakeup
so i get my sub today and i look at the box and instanty notice that it was not the sub i ordered, i got a 10w6-v2 instead of a 12. what is the difference between these subs?
Username: Subfanatic
Walton, Ky
Post Number: 3045
sizes power handling surface area
somethingredicolousihavetomakeup
i mean what will be the sound differance?
Walton, Ky
Post Number: 3049
in my opinion better, i dont care for 12's
thanx, but anyone else know what the aftual differances are, i.e. spl levels and sq mostly
Username: James1115
Wilton, Ct
Post Number: 2601
SQ will be the same but the 12 will get lower.
Username: Suleman36
Post Number: 958
You will hit lower notes with your 12w6v2 compared to the 10w6v2 because i have owned both and went from 10 to 12. They are both clean. I whould stick with the 12.
