Question about symbilink
Username: Scab12886
Post Number: 92
i was looking to get zapco reference amps for my components and sub. i had seen the symbilink stuff and don't really know what it is. can anyone explain it a little to me please? what are the benefits for having it?? also, how much does it cost to get the symbilink balanced lines stuff? thanks in advance.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7761
symbilink is a balanced signal path using higher line voltages to keep a clean, noise free signal path. it's a proprietary signal path that works with zapco's signal processing if you use their pre-amps, EQs, crossovers, etc.
it's far from cheap.
