Eclipse sub question
Username: Williamc
Post Number: 41
i have 800w@ 2 ohms, im between two 10'' SW7104DVC subs or 1 10'' SW9102. i dont have much room which is why i need a 10''. i listen to more rap then rock...any one with experience with either sub please help. thanks!
Username: Subfanatic
Walton, Ky
Post Number: 2994
ti
Username: Williamc
Post Number: 42
i have a very small trunk, where could i get soem box dimensions for just cu-ft reccomended for this sub?
Walton, Ky
Post Number: 2997
u want sealed im guessing
Username: Williamc
Post Number: 43
not in perticuliar, i had a 12'' L7 in a 3.25 cu-ft ported box and it was rediculiously loud w/only 600w. i listen to a lot of rap but sometimes rock. so how does this sub respond to a 1.5-2.5cu-ft ported box? i dont have a sub-filter on my amp(mtx 801d) so is haveing a ported box gunna hurt at all>?
Walton, Ky
Post Number: 2998
i would give ti AT LEAST 3 or 4 cubic feet, in a 3 cubic foot ported box with 550 watts rms tuned to 28 hrts i hit 146.4 on termlab
Username: Williamc
Post Number: 44
hmm. i dont think my mustang can house such a big box. how would this sound sealed? also how many cu-ft should the subbox be if its running off 800w, sealed?
Walton, Ky
Post Number: 3001
2.10 cubic feet after displacement
Username: Williamc
Post Number: 45
anyone? dimensions for a sealed Ti box?
Username: Williamc
Post Number: 46
thanks alot man! do u know anywhere i could get the LxWxH of a 2.10 cu-ft box, so i can make one? (i need the height of the box to be less then 13.5'' and the width to be less then 32'') thanks!
Username: Williamc
Post Number: 47
the driver size is .47cu-ft or at least that what i found on their website. so i went to this box dimension site and typed in i want 2.57cu-ft(2.10cu-ft after driver) and it gave me 13''x28''x16''. does this sound right? sorry for the dubm questions i just wana make this box right.
Username: Tpizzle
Post Number: 165
let me guess subfanatics next response. hell make you one for 50 plus shipping. well see if im right.lol
Walton, Ky
Post Number: 3003
cheesecake
Username: Williamc
Post Number: 48
so are those measurments gunna make this box sound the best it can sealed? sorry guys i dont have much knowledge on box building.
