Ground a power wires
SPLSQ
Will it do anything if I use a 5 gauge power wire and a 9 gauge ground wire, because I heard it better to use same gauge power and ground wire.
Username: Gary_uk
Post Number: 10
you need to use the same gauge.
as long as your amp is ok on 9 then using 5 should be ok as it is thicker. ?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7762
wire gauge requirements are based on the amount of current, and the length of the wire.
http://www.the12volt.com/info/recwirsz.asp
use same size wire for power and ground. period.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1028
I agree. Just keep the 9 gauge run as short as possible. 9 gauge wire has about two and a half times the resistance per length as 5 gauge so from a voltage perspective 1 foot of 9 gauge is analogous to 2.5 feet of 5.
The 9 gauge will get a bit hotter, but 10 gauge wire is good for 55 amps open air(normal insulation). From here:
http://www.epanorama.net/documents/wiring/wire_resistance.html
As long as your amp draws less than say 50 amps(to be safe) you should be fine.
People think that wires are analogous to water pipes in that really small sections create "bottlenecks". If that were the case then we'd be using some awfully big fuses. Nah, length is every bit as important as gauge. Its just easiest to tell everyone to just use the same size wire for power and ground.
-Fishy
