Audiobahn Subs????
Username: Gravy30
Canada, Alberta
anybody got anything bad to say about these? on ebay 2 10" for $85. 300 W RMS, 600 peak. im workin on my first system so i dont need top end, but i dont want crap either, thanks
Username: Subfanatic
Walton, Ky
Post Number: 2921
yea bad
Username: Taylor17
Kopperl, Texas
Post Number: 1528
Wich series are they, my friend has 2 10 dub series, and to tell you the truth... they get pretty loud!
Username: Rob315
Cuse, NY U.S.
Post Number: 446
no not bad......just not in the same category as RE or Adire....they dont have great sq but they get pretty loud...especially for the price. dont just knock it see how much they have to spend and what they are looking for first.
Walton, Ky
Post Number: 2934
yea two audiobahns are not going to touch RE subs or adires, they will get loud no doubt, but not as loud, and the other subs will sound MUCH better while doing it
Username: Hdubb
Farmington, Nm Usa
Post Number: 1356
its not how loud, its how they sound the clarity in the notes, and the response, and that is why they arent very good subs.
Username: Thumper
Richmond, VA U.S.A
Post Number: 42
Trust me, If you want to be happy a couple months down the road, go for the high end stuff. Save up your money. My first sytem was about 500 dollars for two 12" audiobahns at 400 rms/ea + all the wires that had to go with it. Now i went to the immortals pushing 2000 rms/ea. Its not hooked up yet cause it will take some time and money, but trust me, a couple months after you have your system running, youll be craving for more. Bass is like a Drug
Username: Taylor17
Kopperl, Texas
Post Number: 1536
That is the truth!
Username: Jmloughrey
Farmington, CT
Post Number: 1231
yea, i went from 1 12" L5 thinking it'll be enough to 2 12" L5s, then to 2 10" eclipse alums...now i'm at 1 12" Orion HCCA...
might i add the HCCA is better then all subs i just previously listed...
