Alarm System Cut Under Hood
Username: Mrm121998
Rowlett, Texas United States
I have a 1994 Ford Explorer Sport truck. My alarm would not go off one day so I cut the wire under the hood and now my truck will not run. How do I go about fixing the alarm so I can drive my truck again.
Username: Carguy
Post Number: 3150
Michelle, depending on your alarm, it probably has vehicle immobilize. You will either need to have the alarm serviced/replaced or by pass the ignition wire on the alarm. Trace that wire into the alarm, and then find the wire that goes back to ignition wire. Make a cut and wire those 2 together. That should enable your ignition.
