Anybody know where i can get jl 15" w3 for cheap?
Username: Johnnysanz3
Post Number: 43
let me know.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 368
the W3's are hard to find since they stopped making them, the W3v2's are easy to find, ebay and any online store that sells JL
Post Number: 44
ya i meant to write the v2's, thanks
Post Number: 45
i was also wondering if 400 watts is enough for the 15w3v2, its 500 watts rms, and i am going to be powering it with a audiobahn a8000t that is 400 watts rms at 4 ohms
Stockbridge, GA USA
Post Number: 370
if its clean and true, then it should be fine, if you wanted to push a lil more it could take it, JL's are underrated
