Wireing options
what are the wiring options for 2 subs with Dual Voice coils and each coil is 8 ohms?
Username: Subfanatic
Walton, Ky
Post Number: 2703
so dvc 8, u can wire the subs seperatly for 4 or 16 ohms, or u can wire tehm together for like 32 2 or 8 i believe
so i could wire them both to a mono amp and have them wired at 2 ohms?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 522
Plug your info in here and it will show you what you can do http://www.rockfordfosgate.com/rftech/wiringwizard.asp
