What size?
Username: Subfanatic
Walton, Ky
Post Number: 2769
guys what size wiring and what size inline fuse would u guys suggest going to my jbl 1200.1
Username: Carguy
Post Number: 2489
I would use 110A fuse near the battery and 0 - 2 gauge wire.
Walton, Ky
Post Number: 2772
cool thanks, what size alt do u think?
Username: Carguy
Post Number: 2491
I would say at least 150A, but would recommend 200A.
Walton, Ky
Post Number: 2774
well i talked to numerous places and the top they make for me is 150 amps, and i would like 200 as well, do u know where i could get mine erdone, or where i can get one specifically built for me car
Username: Carguy
Post Number: 2494
Have you tried 4alterstart.com? They will rebuild your alternator to whatever size you desire.
For your current situation, 150A will work.
