2 mono 1 ch amps to power 1, 12 sub each
Username: Treeguy2oo4
Phoenix, Arizona USA
Post Number: 12
im going to hook up 2 mono amps two to 2,12 sub each. the amps are pioneer and the subs are pioneer too! ( i like pioneer )
the amps are GM-D510M a 1 ch 600 rms 1000 watts max @ 2 ohms. witch i think needs about 60A to run good! 50 X 2 = 100A X 20%=20. + 100.A=(120.A) plus i'm going to add a 4 ch amp with 25 to 35 rms per ch witch witch is 11.0.A x 40%=4.4.A + 11.0.A=(15.4.A), altogether is about 135.4 amps is what a alternator needs to put out for these amps to run wright, or do i need more for my truck to run good too??? the subs are TS-W3O6DVC 400rms 1000 max watts. i think this is real close to match do you???
ther is more but i'll go in to that some other time!
Post Number: 26
HI
