ORION
Username: Sancho886
El Cajon, CA US
Post Number: 122
whats the difference between the orion 2250sx and the 2250xtr?
Username: Sancho886
El Cajon, CA US
Post Number: 123
bump
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7650
nothing really. same amp. the SX was first and second generation. the XTR was what Orion changed the SX name to after giving the amps a facelift with rounded off cooling fins and the redesigned Orion logo.
Username: Sancho886
El Cajon, CA US
Post Number: 125
thanks for the reply. so i would get full power out of it running at 4ohms mono right? i have a RE HC dual 2ohm vc. would this sub work to get full power out of this amp? thanks.
Username: Glasswolf
Post Number: 7680
yup.
I use two 2250SX amps bridged to drive a pair of dual 2 ohm coil triple X 12" subs myself.
1280wRMS @ 14.4VDC stock. a bit more with modified internals.
nice amps.
I'd kill to get my hands on 3 of the GS500 model amps.. heh that gold plating was pretty. I may have to look into plating costs for the 2250's
