Amp wiring
SPLSQ
How do you parallel wire a mono 2 channel amp? Can someone make a picture and explain it to me?
Username: Kojak28
Augusta, GA USA
Post Number: 136
Parallel and series wiring techniques involve speakers' wiring TO the amp. Are you referring to a 2 ohm stable mono block amp? Give me some specs and some particulars on what you are doing.
SPLSQ
I am going to get a mono amp, its 2 channel and stable at 2 and 4 ohms. My subs are 4 ohm single voice coil, and I want to connect them to the amp at 2 ohms. I need someone to make a picture of how I would parallel wire.
Username: Goon
Post Number: 102
I might be wrong, but I dont think you can wire single voice coil 4ohm to 2ohm, i think it would have to be 4ohm dual voice coil.
anyone correct me if im wrong.
goon
Username: Velk4425
Post Number: 17
http://www.the12volt.com/caraudio/boxcalcs.asp
Username: Treeguy2oo4
Phoenix, Arizona USA
Post Number: 34
bro this guy dos not know what he saying! yes you can get them to 2 ohms. look on the net!!!!!!
Username: Langner
Madison, South dakota US
Post Number: 96
yes you can if you have 2 subs
SPLSQ
You see, you have to read everything, MONO amps are not 2 channel, they are ALL 1 channel (how come no one said that before) anyways the amp mono amp that I am going to get looks like a 2 channel amp, but actually it parallels in side the amp. Like the pic.
http://pic17.picturetrail.com/VOL809/3228131/6595604/93959061.jpg
