Wire Help
Username: Mcazayoux
New roads, La United states
Post Number: 82
i have no idea about wire. what r some decent brands and do yall have any suggestions on what gauge to get.
[2 w6v2s
infinity kappa perfects
probably the PPI that MOs selling]
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 347
wireing depends on length and amp draw.
amp draw is figured out like this
total watts using/12.6 volt electrical system = amps drawn
usually power wire runs go around 16-19 feet depending on your car. and for that length, it goes as follows:
0-20 amps - 8AWG
20-35 amps - 6AWG
35-65 amps - 4AWG
65 - 105 amps - 2AWG
105 - 150 amps - 0AWG
(info from MECP installer cable calculator chart)
the shorter the run of wire, the smaller the gauge you can use, the longer the thicker
hope this helps
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7694
here's a wire size chart:
http://www.the12volt.com/info/recwirsz.asp
here's where to get all of your wiring and interconnects:
http://www.knukonceptz.com/
