Yet again...plz help.
Username: Goon
Post Number: 104
Ok, still looking for an amp to push my 2 12" perfects. How would an mtx amp do in the sq department for these subs? my other options were ppi or an orion, but i'm having touble finding either of these in my price range. the subs are 350rms btw. thanks for the help yet again.
goon
Username: Subfanatic
Walton, Ky
Post Number: 2567
what is your price range, and the subs ohms
Username: Goon
Post Number: 105
im trying to stay under 200. would like to go in the 1-150 range, i know it's low but im poor. they dual voice coil 4ohm...so i could run them at 2ohms i believe. thanks.
goon
Username: Goon
Post Number: 106
boing
Username: Carguy
Post Number: 2449
Try looking for MTX 6500D amp. It puts out 500w rms and usually sell for $120 on eBay.
Username: Goon
Post Number: 107
awsome. mtx was more in my price range...but i didn't want to get the low end models. thanks again isaac.
goon
Username: Goon
Post Number: 110
Ok, So I took Isaac's advice and went with the mtx 6500d, it was more in my price range. Can you(isaac) or any tell me how this amp will work for my 2 infinity perfects, will it do them justice? give me your toughts. and how should i wire the subs? they are dvc 4ohm. thanks again.
goon
