Hey marshal
Username: Insearchofbass
Post Number: 1396
sean,
all you need to test that theory is a clamp meter and an volt-ohm meter.
I wanted to test the resistance while the sub was playing different frequencies. What is a clamp meter for?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 631
The clamp meter is to find the true AC amperage that your amp is producing. The volt-ohm meter it to find AC voltage.
You just do (V)*(A) to get watts (this will tell you what you amp is really putting out at a given freq.). And (A) divided by (V) to find your impedence at that frequency.
Post Number: 1412
oh ok i follow you now
thanks
Post Number: 1413
if i was to buy one of these would i look for anything in particular and if so how much are they?
Post Number: 632
You could get a cheap clamp meter on ebay for like $25 shipped, but I'm wouldnt know about the quality. Personally, I would rather have one w/ a digital display...it would be easier to read.
On the other forums, I hear that Fluke makes a good clamp meter though. I'm looking at prolly just getting one of the cheap ebay ones pretty soon though.
Post Number: 1415
ok i looked on eaby as you said and they are in the 25 buck area digital read....keep me posted on your progress with this stuff.
thanks,
sean
Username: Subfanatic
Walton, Ky
Post Number: 2541
sean, could you help me come up with a slot ported design instead of pvc pipe for taht spl box, im curious to buuld one lol
Post Number: 633
I have an analog clamp meter, but I have never used in to check for true output or box rise. I have seen people use clamp meters to do this...I just havnt had to chanc to do it w/ my amp yet.
Subfanatic...what sub are yall talking about? (just wondering)
Username: Hdubb
Farmington, Nm Usa
Post Number: 1344
hey as.hole subf dont thread jack mr. sassy pants
Walton, Ky
Post Number: 2572
SHUT UP HUNTER, we made a new thread OK!
Post Number: 1423
an eclipse ti 15
