2 12" atlas or 1 15 Ava??
Username: Pharoh
Bradford, Ontario Canada
Post Number: 156
Hey guys. Help me figure this out, im struggling huge, haha. I am thinking of the 2 12" Atlas, but i want Alot of bass and good sq. I am a bass lover. So would i be better of going with one Ava or 2 12"s, Space is not an issue. I have a GMC Safari Van.
Username: Jwbulger79
Florida
Post Number: 484
i think that it's pretty comparable. call the company and talk to chad, the owner/designer. do you already have an amp? keep in mind that that two atlas' can only be wired down to 2ohm, and one avalanche can be wired to 1 or 4ohm.
james has an avalanche, he may be able to answer your question...
Username: Subfanatic
Walton, Ky
Post Number: 2480
someone on here asked chad over there, and he said that 2 12 atlass and 1 ava are very very cvey exactly the same in output of both i belibve
Username: Pharoh
Post Number: 157
hmmmm.... lol that helps me this much | | lol
Username: Insearchofbass
Post Number: 1393
do the single 12 and make an optimized box for it youll have more room to experiment with that way plus you prob have beter sq becuase its the higher line
Post Number: 1394
and if you like it that much you can save up and buy another and your good to go either way lol
Username: James1115
Wilton, Ct
Post Number: 2408
the avalanche will have about 1db output over the atlas' in the same enclosure with ideal power.
