New Aduio system
Username: Kurby88
Chattanooga, Tn USA
im getting a fully loaded 01 zx3. i dont know what the speakers sound like so im wondering, sence im getting a 10" sub, will teh stock speakers be ok, or should i look into getting more speakers.
Username: Subfanatic
Walton, Ky
Post Number: 2354
josh, with the sub your getting your speakesr will be fine, and will prolly blend well, but if you want to upgrade, some cheap alternatives are MBquarts and infinty references
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 388
Not to mention, CDT makes a good set of cheap comps as well.
