Kicker Box Dimensions
Username: Diamondzsz
Baltimore, MD USA
Does anyone have any dimensions for a small enclosure for a Solobaric 15 (L7)? I would like to test this sub out in a small enclosure, but cannot seem to find any posted specs. Can anyone help?
Username: Subfanatic
Walton, Ky
Post Number: 2326
Single 15" Hatch Enclosure • Kicker L5 and L7 woofer cutout • Sealed Design • Volume - 1.5 cu ft airspace • 16 1/2" h X 16 1/4" bd X 9 1/2" td X 18" w
Username: Insearchofbass
Post Number: 1343
should work decent that box will probably end up being 1.30 cf after displacement .....it should come alive at 60 hz to 65 hz range
Baltimore, MD USA
Thanks for the measurements. I will start working on this, this evening, and should have some results for you by weeks end. I will post. Thanks, again, Subfanatic.
