JL or RF SUBs
Username: Ruckus
Oh
I am adding some subs to my setup and I was debating between JL and RF, if i go with the JL it would be 2 12w3v2 with a 500.1 JL, or if i can afford it 2 12w6v2 with a 1000.1 JL, on the other hand I could go fosgate and run 2 Punch stage 3 (p312d4) with a Punch 6002 or for a little more 8002, can someone help me decide, the 12w3v2 and the p312d4 setups are close in price but the RF subs, can handle more power..... any insight would be appriciated, or tell me an alterative setup
Username: Subfanatic
Walton, Ky
Post Number: 2368
i would take jL in either applications, but if you can, try and save and go with the 1000/1 idea
Username: Taylor17
Kopperl, Texas
Post Number: 1452
The w6v2's are the best choice.
The w3's will have better sq than the RF's.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 340
i'd go with the JL's, either Jl set up would be better then the RF imo
