Question...
Username: Freeriderz05
Gattikon, Zurich Switzerland
What is the main difference between the JBL BTX 250 or another tube woofer and a regular sub in a box?
Username: Carguy
Post Number: 2408
Difference as in SQ? Besides the physical difference, not much performance wise. Most people with limited space buy tube subs.
For best SQ, a sub in a proper box will sound much better.
Ok thanks would the btx be a good choice if i was getting a tube?
Username: Carguy
Post Number: 2410
It sounds like a decent product. I'm not really into tube subs cause I didn't find one that fit my quality standard.
Post Number: 7
ok im looking to put it in my room at home :D what do i need
Username: Carguy
Post Number: 2414
You'll need 12v power supply (around 15A-20A)since it has built in amp. That's about it.
Post Number: 8
OK thanks alot and dont i need some kind of spit cable to connect my subwoofer out on my dvd player to the white and red rca on the sub?
Username: Carguy
Post Number: 2415
Well you will need rca cable to connect it to the tube sub but that's given.
You don't need a splitter unless you're planning on sharing the dvd player's output with another amp.
Post Number: 9
ok one last thing where can i get a converter designed for this and how much is it gonna be i.e is it cost effective
Username: Carguy
Post Number: 2417
Converter as in power supply? You can get one from most electronic/hobby stores. eBay has it too. Look for any 12v power supply with 15A-20A. The cost will vary anywhere from $30 - $100.
You could build your own for probably less.
Post Number: 10
Ok thanks alot
