1 Ohm Stable....help
Username: Scubasteve101
i want to hook up 3 subs to an amp that is stable down to 1 ohm. I was wondering if it is stable only at exactly one ohm or if it could run at 1.34 ohms. I know it says its stable DOWN to one ohm, but i'm just making sure.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 629
yes...you can run the amp at 1.34ohms.
Stable down to 1ohm means dont go UNDER 1ohm.
thank you very much, that just made my day!
