Is their an expert that can help plz?Woodstock DAB 52 car radio by BLAUPUNKT
Username: Webmailer
Hi. My Woodstock DAB52 car radio by Blaupunkt stopped working today.
I installed it yesterday and it worked all day, but today I put in a C.D into the CD player and it stopped working.
What could be wrong with the unit????
Username: Westcoastsound
okay try this: un-hook your stereo and connect it directly to your car's battery. Get the Power and accessory cables from your stereo and put them on the (+) terminal and the ground cable to the (-) terminal. If it turns on it works if it doesnt then... you know, but if it turns on then all you need to do is replace a fuse on your car.
