Wiring a Head Unit
HandBlown0990
My buddy has a cd player for sale. But, there isnt any wires coming out of it. He says u can just go pick the harness up and thats all there is to it. Is it really just that easy or should I consider looking somewhere else?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7540
I wouldn't buy a head unit without the wiring harness unless you already know where to get the exact harness for that make and model of stereo.
Do you know the speaker wiring diagram for a PIONEER DEH-P3600? I can't find my wiring diagram. Thank you. The colors of the wires are...White/Grey/Purple/Green there are two of each....one of each has a black stripe...I'm sure that the blak stripe is my negitive.
Hey listen i put an after market head unit in my 94 jeep wrangler i hooked it up just the way it was supposed to be, now my jeep wont start, i have replaced the battery, the fuel filter,distributor cap, halifax,coil,crank sensor,fuel pump relay and i think thats it, what could be the problem, it will turn but not all the way over it just keeps cranking
