Bronze Member Username: Loc_outPost Number: 56 Registered: Feb-05 | How good is JBL 1200.1? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 7581 Registered: Dec-03 | on a scale of 0 to 1? it's a 1. good amp. 1 ohm stable. 1200 watts RMS @ 1 ohm and 2 ohms 600 watts @ 4 ohms two sets of speaker terminals for ease of wiring two subs. 4 RCA inputs for front and rear L/R |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2057 Registered: Dec-04 | glass, what is great about the 4 RCA inputs? i dont get it lol |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 7588 Registered: Dec-03 | if you have a head unit without sub outs, and you have F/R RCA outs, this allows you to fade front to rear without affecting sub level. |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2062 Registered: Dec-04 | ohh ok, tahts awesome, thankms, but while i have your attention, i need a nice opinion, im giong to run a jbl 1200.1 to my 15 eclipse TI and iw ant to use all 1200 watts to it, but what kind of enclusure (ported preferbly) should i use, and what should i tune it to in your mind, i want good spl with decent sq |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 7592 Registered: Dec-03 | ported, about 3cu ft volume, tuned to 28Hz that'd sound nice |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2118 Registered: Dec-04 | hmm, that sounds nice, any cahcne yo know where i can find dimensions for this, or you could help me with it, im horrible with boxes |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 7596 Registered: Dec-03 | well, any dimansions that result in 3cf after driver and port displacement are added in will work. LxWxH for that. as for figuring port length, if you go with a round port, use 6" ID tube, and calculate length to tune for 28Hz. It'll be a fairly long port so a slot-vent may be prefered as you can wrap that around two of the interior walls of the enclosure if need be. www.bcae1.com has calculators for figuring a ported box though. you have all the data you need to plug into the calculators. |
