Can you do this
delicious
can i run 2 audiobahn 1206t dual 4 ohm subwoofers at 1 ohm mono on a kicker 1200.1 would that work (i dont know anything about car audio other than i like it)
delicious
if not can someone suggest a different amplifer for the 2 subs
Username: Byrumjr
Post Number: 196
yes Upload
Username: Byrumjr
Post Number: 197
The audiobahn 1206t needs to be around 600 rms each. If they are not they might blow.
delicious
so would that setup work??? or do i need a bigger/smaller amplifier
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 353
It will be a nice light show!
