Sony cdx-1150: how do I set the clock?
does anyone know how to set the clock on a Sony cdx-1150 car radio?? I know that you hold down the display buttone for 5 secs to get the hour to blink and the volume changes the hour. But how do I set the minutes? Would appreciate all info. If anyone has a copy of the operations manual sheet(or knows where to find one for no charge on the net), I would really like a copy.
Username: Illuminator
Post Number: 22
I've never owned this model or used it, but I think it would be best if you tried a few other buttons while the hours blink, especially the seek/tuning button.
Sweta
Hi,
First hold down the display button till hour blinks. Use volume to change the hour. Then hold down the select button. This will cause the minute to blink. Again use volume to change the minutes. Then hold the display button again to come out of the clock setting mode.
