12 inch sub or 15 inch sub?
Username: Langner
Madison, South dakota US
Post Number: 70
i was wondering what would sound better 2 12's or 2 15's because im not sure
Username: Suleman36
Post Number: 570
For sound quality to 12's will sound better and for spl 2 15's will be louder.
Username: Mad_at_madd
Chico, CA USA
That really depends on what brand you get and many other factors. However, normally speaking 2 12" subs are more versatile in producing the low, deep, rumbling bass of rap as well as the punchy, short, tight bass of rock. If you listen to rap the 15's are the way to go, if you listen to rock or anything else that has tight, punchy bass 10's are the way to go. If you listen to a little of everything the 2 12's would be the best choice.
Also, it really depends of the user's perference. Every sub has a slightly different texture of sound it produces.
Username: Langner
Post Number: 72
i found something jus for now to put a lil thump in the trunk yah know but idk how long it would last
http://www.cardomain.com/item/BLAPCA12COMBO
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 280
Don't do it Chris. Save your dough for a better set up, unless you like wasting money. If thats the case I am always willing to take it =)
