Another question!....?
CrazyInsane
someone wanna give me a smart guess lol. which do you think would be louder.... 3 JL 10w7's sealed with 500 watts each, or 1 15" x.x.x. ported with 1200 watts, and does anyone know of a good, not toooooo expensive amp for 1500 watts rms at 1 ohm??
CrazyInsane
or the 15" x.x.x. in a ported box compaired to the 3 jl 10w7's in a ported enclosure? which do you think would sound better and be louder!
thanks!!
Username: 54danny54
Post Number: 190
ok first of all...jl will get louder...second the hifonics brutus 1500D...not efficient but it puts out www.woofersetc.com
InsaneCrazy
ok, but i mean a better amp than that lol. like $350-600 ish range or an ebay one that would work well! and you think the 3 10w7's sealed would get louder than the 15" x.x.x. ported?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 235
i believe the PPI 1500.1 is a good amp for 599 on www.woofersetc.com
Username: Pga1990
Whitehall, Michigan United States
i got a great amp on ebay
3200 watts for about 33 bucks
add shiping and it was 59
check the bids that are just about to end on amps
you should get a great deal
Username: Jmloughrey
Farmington, CT
Post Number: 1193
damn shame your amp wont put out ANYWHERE near 3200 watts....well correction, it may...at about .05ohms right before it sets itself ablaze...you get what you pay for...
CrazyInsane
haha anyone else have any other ideas on a pretty good amp thats 1500 watt rms at 1 ohm?! from like $350-650 ish... besides the ppi 1500.1 and the brutus?
CrazyInsane
ZRS-8 - Cadence 1500 Watt Mono Amplifier....$628.99 1500 watts at @ 1 ohm.... hows that, anyone ever used cadence amps before?
CrazyInsane
Bump
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 595
kicker Kx1200.1
Username: Solacedagony
New Jersey US
Post Number: 345
Mm Gotta love those 3200W amps that only cost 33$! I got a great deal! hahaha.
Cadence is a pretty decent brand. You can usually gauge the quality of the product by the price. Just look around at a few places and get an average price that the product goes for. Of course, that doesn't ALWAYS work, but you get the idea.
