1994 ford f-250 stock radio wiring
Username: Brentcarl84
U.s.a
I am trying to wire the stock radio back up. The wires were cut from the harness so i tried to match them up and connect them. The power comes on, speakers work, fade and balance work, but the channels keep changing. It will stop at a channel for a few seconds and then move on to another one. What's wrong, how do i fix it???
Username: Illuminator
Post Number: 192
You have the antenna hooked up to the back of the unit, correct? And do you have the stereo on station scan or some equivalent?
U.s.a
The antana is hooked up and stations will come in, but it moves on like you push the seek. There is no station scan or anything like that. I've hooked another radio similar to this one up and it will do the same thing.
Post Number: 211
Hmm...here's a link to a wiring diagram so you can see if it really is a wiring problem...http://www.streetdreams.com/wires/ford/general-1993-98.html
