Anyone have a mmats d200hc?
Username: Mrdark
Post Number: 69
i just bought one. it plays, the frequency adjustor works anf the gain also works. it just doesnt play the subs hard at all, even with the gain almost all up. anybody know what could be causing poor performance?
thanks.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 489
probably you have the subs wired wrong to a higher ohm load, and turn the gain down some, its not supposed to be turned up more than half way.
Username: Mrdark
Post Number: 70
ya...
they were wired in parallel. 2 dual 4 ohm subs...
a 1 ohm load. they didnt hit even at 1/2 gain...thats why i turned it up.
thanks for thinking im a rook, but also for responding...
