2 Avalanche
Username: Loc_out
Post Number: 28
I'm thinking about buying two Avalanche. what amp would you guys recommend? Also what type of box do you guys recommand?
Username: Suleman36
Post Number: 544
The jl 1000/1 whould be a good amp to start with. To be honest,you wont even need 2 15" Avalanche from what people tell me on the ascendantaudio forum. IM gonna run my single off a 500/1 and chad the owner said it should be fine. James has his off 600 wattsrms. They are very efficiant even if you underpower them.
Username: Alpineuser
Post Number: 180
im gonna run 2 15s off an jbl bp1200.1. the avalanche is best suited for sealed but i would go with a low tuned ported box tuned from 25-30hz range
Username: Loc_out
Post Number: 29
Thanks for the input.Alpine what car do you plan on putting does Avalanche?
Username: Suleman36
Post Number: 545
what kinda box are you going with?? IM trying to decide on mine.
Username: Loc_out
Post Number: 30
I dont know i have a Yukon but i dont want to lose the 3rd seat!
Post Number: 182
im gonna put mine in a full size bronco (my baby). i have enough room for about 17cf and only be at seat level, but im probably gonna do 10cf for 2 for now
