Bronze Member Username: MacdizzlezMassachusetts Post Number: 14 Registered: Sep-04 | Ya im running 2 12 inch brahmas with a kicker 1200.1 my lights dim at night what do i need?a battery or a new alternator.. i got a 140 amp alternator in my car now. |
Silver Member Username: Suleman36Post Number: 511 Registered: Feb-05 | Try looking for a optima yellowtop under your hood and a 1.2 farad cap tied to your kicker 1200 and that should work. |
Silver Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 900 Registered: Sep-04 | A new battery won't help(except with engine off), but a cap might.... a lil. As long as your lights dim only momentarily and don't stay that way you're probably ok. 140 amps is pretty good size alternator, but remember alternators don't perform near as well when your car's at idle. -Fishy |
Silver Member Username: TheelfkeeperStockbridge, GA USA Post Number: 262 Registered: Feb-05 | your lights will always dim some unless you completely remove your system from the rest of the car's electrical system due to the size of the wires run to the system compared to the rest of the car's electrical wires. caps can help, but not a cheap 1 farad tube kind. look at batcaps and allumapro caps |
Silver Member Username: Suleman36Post Number: 516 Registered: Feb-05 | Look into the batcap model 800 stereo battery. Its 70%battery/30%cap and trust me that 30% is equal to over 3 caps. Search for Batcaps on ebay and look for the model 800 and read about it if you want more info. I bought mine from ricktw. He has a online store on ebay for batcaps.. he is great to deal with and ask questions. Been in the business a long time. here is a link actually http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796%26item%3D5764935027 %26%26 |
