Kicker amp for 18"x.x.x.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 169
Does anyone know if this is any good for a 18"x.x.x. ?what about the spec anyone?anyhttp://www.smarter.com/specification/2493434-KICKER_LivinLoud_SX_Series_Class_D_ SX1250.1___Amplifier/
Username: Fordpwr
Los angeles, CA Usa
Post Number: 178
Username: Tragedy
San Jose, CA
Post Number: 185
1250rms is good for the sub assuming it puts out a full 1250rms.
But for the $700 you can get a Zapco REF 1100.1 that puts out 1100rms at 2ohm (get a custom 4ohm sub) and that would outpower the kicker amp for about the same price if not cheaper with alot better sound. Hit me up if your interested on the Zapco i can get you a good price from an authorized dealer.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 491
that SX1250.1 will prolly bench at about 1400wrms...most kicker amps are underrated.
i have seen kx1200.1 that bench at 1500w+. that sx1250.1 should be a nice clean amp to run your x.x.x. on. kicer amps pretty nice, i am about to buy a kx1200.1 for my SX15.
that zapco amp that TraGedy suggested would be a nice amp also.
Username: Jmloughrey
Farmington, CT
Post Number: 1115
get a boss :-)
Post Number: 499
yea...boss the the shiznit (or rather a piece of sh!t). lmoa
I used to have a boss r1400d...its was "rated" for like 1400w at 1ohm and had a 40A fuse. Then i got a jbl bp600.1. The bp600.1 handed the boss its a$$...lol
Username: Subfanatic
Walton, Ky
Post Number: 1883
haha
Username: Sqeeks80
If kicker amps are under ratered, what will the KICKER KX600.1 bench at?
Username: Sqeeks80
Post Number: 7
Post Number: 507
Most of the KX600.1's I have seen benched at 700w+.
Post Number: 508
I had a kx600.4 that benched at 740w+ once.
Username: Sqeeks80
Post Number: 8
So a kicker KX 600.1 is good enough to run one Kicker L7 (4ohm,750 watt rms)?
Username: Alpineuser
Post Number: 129
i had a jbl bp600.1 and there is no way that amp pushed only 600 watts that thing pounded the feces out of my type rs
Post Number: 510
yea...a kx600.1 would be a great match for an L7. (dvc 4ohm)
alpinethumping,
i used to have a bp600.1...it is a darn good lil amp. I ran it on an L5 12" and then switched over to a brahma 10"...i was doing ~134db w/ the brahma 10" on that bp600.1...and it sounded great. Now i use a bp1200.1 and it hammers on my SX15 (145db+). For price, you cant beat the JBL BP series...IMO. Its to bad JBL discontinued them. I'm prolly bout to ebay my bp1200.1 so i can get an amp to run in USACi 0-300w class though.
Username: Sqeeks80
Post Number: 11
what about the Kicker kx800.2...bridge that to run the L7...or will that be over powering the woofer?(RMS Power (WATTS/CHANNEL), 2 Ohm Stereo: 425W x 2
RMS Power (WATTS/CHANNEL), 4 Ohm Bridged Mono: 850W)
Username: Kenwa
Post Number: 91
that amp would run 2 kicker L7s if you got the dual 4 ohm version and wired them at 2 ohms and ran the amp in stereo, well depending on the size of subs, i know for sure that would be enough for 2 S10L7s
Post Number: 528
You cant wire a pair of DVC 4ohm subs to get a final nominal load of 2ohms. You could do it w/ a pair of DVC 2ohm subs though.
W/ a pair of dvc 4ohm subs you can get a 1ohm, 4ohm, or 16ohm load.
I would run the kx600.1 on the L7 if i were you. The kx800.2 may be a lil too much power, and if you clip the amp you will fry your sub in a heartbeat. If you go w/ the kx600.1 get a dvc 4ohm sub.....or get a DVC 2ohm sub if you go w/ the kx800.2.
Username: Kenwa
Post Number: 96
You can wire two dual 4 ohm subs for a 2 ohm load with each sub, i didnt mean together but the amp is 2 channel and 425 watts per channel at 2 ohms in stereo operation. Just b/c you are using 2 subs doesnt mean you have to wire them together. If you have the money get the kx800.2 and two dual 4 ohm L7s.
Username: Sqeeks80
Post Number: 16
here is the pic of the sub,its a 12"...here's the specs Kicker 12" Square Solobaric Subwoofer
4 ohm,750 watts(Rms)1500 peak...now is the kx600.1 good enough or not? Upload
Post Number: 542
Kenny...I understand exactly what you are saying.
But if you have 2 subs that have a 2ohm nominal load each (dvc 4ohm subs wired parrallel) and wire each sub in parrallel to a 2ch amp (one sub to each channel)...then the amp will see a 1ohm load. This is why I say that you can only get a 1 or 4ohm load out of two DVC 4ohm subs.
Quinton Choudree...if that sub is a DVC 4ohm sub, then yes. The 600.1 would be a good amp for that sub.
Username: Kenwa
Post Number: 99
to achieve a 1 ohm load wouldnt you have to wire both subs together like this?
Post Number: 165
yea and for a 4 ohm load u would wire + to -
Username: Kenwa
Post Number: 100
yeah i know that but marshall is trying to tell me if you wire each sub like the picture below and hook them up to separate channels on an amp the amp still sees a 1 ohm load, is that right?
