Volfenhag sub review
Username: Jessecapper
i have a volfenhag sub... its sounds great with my soundstorm amp and i was just wondering what you all thought of this brand.
Username: Insearchofbass
Post Number: 1232
i personally like volfenhag but most dont one here ...it has a nice sound decent spl and runs in a small enclosure....as for soundstorm i had one biggest piece of junk got hot and shut down in like 20 mins returned it once and got another and the new one did it too....later sold it to someone and told them about the amp up front and shut down ocassionally for them also....it was the 350.2 i think.....the rms power was way way over rated....id say true power sounded to be 200 to 250 rms.
Username: Langner
Madison, South dakota US
Post Number: 43
i have a friend that has 4 volfenhag subs 2 12 inch 1000 watt subs and 2 12 inch 500 watt subs and a 760 x 2 and 650 x 2 and i would have to say that they are a good sub they sound da.mn good for the price
Post Number: 9
yes i agree with you on the soundstorm mine has shut down once or twice... does sound like its not putting out.
Post Number: 1234
which one do you have? Also if i was you id return it but on the positive side they do come with a 5 yr warranty if you cant or sell the amp because an amp that shuts down wont last for the long haul
Post Number: 1235
wait a min that sub is a dual voice coil and if i remember right the sound storm is only 4 ohm stable bridged a dual 4 ohm is able to be wired 2 or 8 ohm bridged
Post Number: 12
i have the f500.2 i didnt buy the warranty for mine. but i will sell it
Post Number: 1236
it should come with the warrranty for free mine did
Post Number: 18
huh.... i will have to check
Post Number: 19
it says here http://www.justamps.com/Amp_Pages/SoundStormLabs/SSL_FORCE.htm
that the f.500.2 is 2ohm stable
Post Number: 19
