What are some great matchups to the eD NINe.1 amp?
Username: Terps297
Potomac, MD USA
Post Number: 83
requirements:
15"
good high and low end
capable of handling 900 watts @ 2 ohms
or
capable of handling 1200 watts @ 1 ohm
Username: Terps297
Potomac, MD USA
Post Number: 84
matchup meaning subs, not other amps
sorry
Username: Invain
Michigan United States
Post Number: 1920
X.X.X's and Brahma's will both sound great off them. You don't have to run the subs on their max ratings to reach full excursion, 1200 watts would be plenty.
You could also run an ID MAX to it at 2 ohms.
Username: Subfanatic
Walton, Ky
Post Number: 1943
Eclipse Ti 15
Username: Terps297
Potomac, MD USA
Post Number: 86
i heard that the x.x.x has a nasty roll off point. does this mean that it cannot produce any higher frequencies? or is this just determined by the box that it is in
Username: Terps297
Potomac, MD USA
Post Number: 87
subfanatic, i was talking to an installer and he said that the ti needs at least 1500 watts to actually reach it's full xmax, i know you have one so is he correct or can the nine.1 actually make that sub pound, in some of the realmofexcursion videos the ti's aren't even moving and that worries me, but since they don't post the power ratins i'm left with just worries and no answers.
Walton, Ky
Post Number: 1946
what the hell, that installer is a retard, its rated at 1500 max and 750 rms, but it is severely underrated, in a sealed enaclosure i wouldnt push more than 900 watts to it, but yea if you put it in a nice box it can take 1500 prollly, all subs can take more than they are designed to do, but BS on that 1500 rms, hes an idiot IMO
Username: Invain
Post Number: 1923
Yeah, the Ed Nine.1 would match up very nicely to the TI. The Ti is rated at 750 rms, but can take the Nine.1's 900 rms @ 2 ohms.
As for the nasty roll of point of the X.X.X, that's b.s. too.
Walton, Ky
Post Number: 1957
hm, what you guys think about a jbl 1200.1 for the eclipse, what are its specs
Username: Terps297
Potomac, MD USA
Post Number: 91
if the ti can handle it, why not, 1200 watts into the ti would be pretty sick
Username: Geekbike
Post Number: 84
The nine.1 is underrated by at minimum 10%. I've seen bench tests with them hitting high 14's.
Walton, Ky
Post Number: 1961
what are the 1200.1 specs
