Crossover in door?
Username: Bobo123
Post Number: 105
I figured this would be a bad idea because of things like moisture/rain in the doors. But, it would make things much easier to place them there. I figured I could make a water proof casing to suround them. would they get to hot if wrapped up. I need some ideas here. If there is any possible safe way to do this please help.
Are you talking passive or variable/electronic crosovers?
Passive crossovers are simple components usually 2-3 components ea. I have installed them in doors and have not had any problems. I usually tape the ends so that they dont short with the other components. Make sure that you keep them close together.
Electronic/variable crossovers are usually installed before the amp and may be as large as a head unit. I hope you werent talking about this type.
Username: Jonathan_f
GA USA
Post Number: 3621
Typically it's a good idea to keep the crossover out of the door, but if you fabricate some form of drip shield then it'll be ok.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 202
Where do you suggest to mount the crossover? I have mine next to my amp in the rear of my truck, is that okay?
Username: Mixneffect
Orangevale, Ca. USA
Passive crossovers should be as close to the speaker as possible.
Electronic/variable crossovers are installed between the HU and the amp.
