Single 4 ohm sub?
Username: Langner
Madison, South dakota US
Post Number: 28
i am thinking and probably going to get 2 12 inch eclipse solid aluminum cone with a single voice coil and 4 ohm nominal impedence?...and i was thinking about gettin a audiobahn 800 watt 2 channel amp...what do you think should i find a differant amp or stick with this one?
Username: Taylor17
Kopperl, Texas
Post Number: 1323
Wich Audiobahn amp? And could you post the spec's on that amp?
Username: Langner
Post Number: 29
A8002T - Audiobahn 2 Ch 800 Watt Amplifier
200 X 2 at 4 Ohms Stereo
400 x 2 at 2 Ohms Stereo
800 x 1 at 4 Ohms Mono
Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D
COMMON FEATURES
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Semi-double Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz - 750Hz
Variable 18dB Low-pass Crossover: 50Hz To 120Hz
Bass boost on/off
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload; Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Air Induction Fan Cooled
RCA and Speaker Level Inputs
Username: Taylor17
Kopperl, Texas
Post Number: 1325
Thats a pretty good amp. It should work, and sound extreemly good. The Eclipse's you are talking about, they are the 7124? They are a really great sq sub...
Username: Langner
Post Number: 32
yeah they are the 7124's
Username: Taylor17
Kopperl, Texas
Post Number: 1331
Yup, they are really nice sub's, you should be really happy with them.
