Speaker wiring for 2 subs in parallel
Username: Dfresh
I'm not sure what the best way is to connect 2 wires to the speaker terminal cup. Should I just take both wires and crimp them together in the same spade connector or solder them? Or is there some other way I should do it? Any help is appreciated.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 884
Thats usually how I do it.
-Fishy
Username: Carguy
Post Number: 2289
Soldering is the best, as long as it's done properly.
