Speaker grill cloth covering slot port?
unregistered
3"wide x 8"high slot port mounted on the baffle which also acts as my trunk floor (building down into the trunk).
Now instead of just having a visable opening can speaker grille cloth be stretched tightly over to cover the opening and still act functionally as a port with no turbulence or port noise?
unregistered
help
Username: Jmloughrey
Farmington, CT
Post Number: 1116
itll probably cause port noise...or make some kinda of rattle sound, ports are meant to be open...
Username: Fordpwr
Los angeles, CA Usa
Post Number: 182
yeah, don't cover the port. just leave it open
