Atlas 12 kicks a$$
Username: Jwbulger79
Florida
Post Number: 357
i installed my atlas 12 last night. anyone looking to spend $100 to $150 on a sub and power it with 200 to 400 watts, check out www.ascendantaudio.com !! i have it in a 1.5ft^3 sealed enclosure and i'm giving it 230 watts from my memphis amp and i'm very impressed with what it can do. it's louder than i expected; it hurts my ears to listen to it real loud for more than a few minutes - with 230 watts? what? i havent even gotten a chance to mess with my amp settings or add any recommended polyfill either.
the atlas has a second voice coil that is used to adjust the Qts - it changes the way the bass sounds, not a bass boost, it's hard to explain, if you're looking at a graph of the frequency and the rolloff at lower frequencies, it adds a "knee" or a little "punch" at that bottom end rolloff point. i installed a potentiometer in my console which allows me to control the second voice coil, or the Qts, "on the fly". it's sweet.
Username: James1115
Wilton, Ct
Post Number: 2073
nice man glad to hear it!
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 55
Good SQL? Do you happen to know the depth of it, I couldn't find it anywhere. I wanna put one in a custom box under my back seat in a 02 Silverado.
Florida
Post Number: 358
Mounting depth is 6.5".
yeah. it hits hard and sounds good. the potentiometer, which is basically like taking the wire jumper off and on the second voice coil allows me to switch from low Qts , which is better for SQ, to high Qts, which gives me a lot more SPL.
my enclosure is 1.5ft^3 with no polyfill. that was the high end of the recommended enclosure sizes, so you can probably get away with 1.0ft^3 with polyfill and be fine, but you'll want to call and ask to be sure. the recommended box sizes on the website were slightly diff than what they told me over the phone - 1.0 to 1.5.
Florida
Post Number: 360
for anyone interested, the potentiometer is part # ct2155-nd at Digikey.com - $3.61.
Florida
Post Number: 361
you'll need a knob for it too (if you want it to look good). i got part # 226-4021-nd , but there was a bunch to choose from.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 58
Sweet. Does it make any difference if the box is longer than it is tall? Thanks for the info.
Username: Invain
Michigan United States
Post Number: 1872
Dimensions don't matter. Just the volume.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 59
Excellent, thanks for the quick reply.
Username: 54danny54
Post Number: 125
lol wehats a potientiometer
Florida
Post Number: 390
a variable resistor. adjusts resistance, measured by ohms.
